| | web www.es.co.th | |
| ลำดับที่ | รายการ | จำนวนตัว |
| 1 | 1N5817-EIC DIODE SCHOTTKY 1A/20V (http://www.es.co.th/detail.asp?Prod=35300433) | 1 |
| 2 | BC547 Transistor NPN (http://www.es.co.th/detail.asp?Prod=13603211) | 6 |
| 3 | CERAMIC DISC CAP 22pF/50V (http://www.es.co.th/detail.asp?Prod=15800352) | 2 |
| 4 | Crystal 16MHz (http://www.es.co.th/detail.asp?PROD=90000118) | 1 |
| 5 | DC Jack ขนาด 2.35mm. (http://www.es.co.th/detail.asp?Prod=17101416) | 1 |
| 6 | DIODE BRIDGE RECTIFIER 1.5A (http://www.es.co.th/detail.asp?Prod=18300046) | 1 |
| 7 | Electrolytic Cap 470uF/25V (http://www.es.co.th/detail.asp?Prod=56602505) | 2 |
| 8 | I.C. SOCKET DIP SOLDER TYPE 28 PINS (http://www.es.co.th/detail.asp?Prod=00712401) | 1 |
| 9 | I.C. SOCKET DIP SOLDER TYPE 16 PINS (http://www.es.co.th/detail.asp?Prod=00711188) | 1 |
| 10 | LED 7-SEGMENT 4 DIGIT COMMON CATHODE (http://www.es.co.th/detail.asp?Prod=01300749) | 1 |
| 11 | LED BAR, GRAPH 10 SEGMENT (http://www.es.co.th/detail.asp?Prod=01005214) | 1 |
| 12 | LED Round3 mm,150 mcd, Red Color (http://www.es.co.th/detail.asp?Prod=01002251) | 2 |
| 13 | NTC THERMISTOR (http://www.es.co.th/detail.asp?Prod=17501547) | 1 |
| 14 | P.C.Board Socket 1x2 Pins Female Header (http://www.es.co.th/detail.asp?Prod=00704207) | 11 |
| 15 | P.C.Board Socket 1x3 Pins Female Header (http://www.es.co.th/detail.asp?Prod=00706301) | 2 |
| 16 | P.C.Board Socket 1x4 Pins Female Header (http://www.es.co.th/detail.asp?Prod=00705702) | 1 |
| 17 | P.C.Board Socket 1x5 Pins Female Header (http://www.es.co.th/detail.asp?Prod=00705533) | 1 |
| 18 | P.C.Board Socket 1x8 Pins Female Header (http://www.es.co.th/detail.asp?Prod=00705877) | 4 |
| 19 | P.C.Board Socket 1x10 Pins Female Header (http://www.es.co.th/detail.asp?Prod=00704398) | 1 |
| 20 | P.C.Board Socket 1x14 Pins Female Header (http://www.es.co.th/detail.asp?Prod=00704327) | 1 |
| 21 | PHOTO CONDUCTIVE CELL (http://www.es.co.th/detail.asp?Prod=24600015) | 1 |
| 22 | POLYESTER FILM CAP 0.1UF/63V (http://www.es.co.th/detail.asp?Prod=19800338) | 2 |
| 23 | REGULATOR +5 VOLTS 1 AMP (http://www.es.co.th/detail.asp?Prod=13601688) | 1 |
| 24 | RESISTER NETWORK 1K-OHM 5PIN (http://www.es.co.th/detail.asp?Prod=15017886) | 1 |
| 25 | ROTARY POTENTIOMETER 10K (http://www.es.co.th/detail.asp?Prod=45300023) | 1 |
| 26 | SWITCH:50mA,TACT SWITCH,7.0mm (http://www.es.co.th/detail.asp?Prod=17101049) | 9 |
| 27 | Buzzer (http://www.es.co.th/detail.asp?Prod=23700027) | 1 |
| 28 | DS18B20 (http://www.es.co.th/detail.asp?Prod=06700549) | 1 |
| 29 | PIN HEADER CONNECTOR 40 PINS (http://www.es.co.th/detail.asp?Prod=00711237) | 1 |
| | web www.arduinoall.com | |
| 30 | P.C.Board Socket 1x6 Pins Female Header (http://www.arduinoall.com/product/475/2-54mm-1x6-6pin-gold-plated-single-row-straight-female-pin-header) | 1 |
| 31 | IC Arduino ATMEGA8 with Bootloader (http://www.arduinoall.com/product/411/ic-atmega8-arduino-%E0%B8%AA%E0%B8%B8%E0%B8%94%E0%B8%84%E0%B8%B8%E0%B9%89%E0%B8%A1-atmega8-16pu-16mhz-%E0%B8%9E%E0%B8%A3%E0%B9%89%E0%B8%AD%E0%B8%A1-arduino-atmega8-bootloader-%E0%B8%A3%E0%B8%B2%E0%B8%84%E0%B8%B2-35-%E0%B8%9A%E0%B8%B2%E0%B8%97) | 1 |
| 32 | สายจั้ม (http://www.arduinoall.com/product/9/%E0%B8%AA%E0%B8%B2%E0%B8%A2%E0%B9%84%E0%B8%9F-jumper-%E0%B8%88%E0%B8%B1%E0%B8%A1%E0%B9%80%E0%B8%9B%E0%B8%AD%E0%B8%A3%E0%B9%8C%E0%B9%81%E0%B8%9E%E0%B9%87%E0%B8%84-65-%E0%B9%80%E0%B8%AA%E0%B9%89%E0%B8%99) | 1 |
| 32 | Module USB to TTL (http://www.arduinoall.com/product/455/%E0%B8%95%E0%B8%B1%E0%B8%A7%E0%B9%81%E0%B8%9B%E0%B8%A5%E0%B8%87%E0%B8%AA%E0%B8%B1%E0%B8%8D%E0%B8%8D%E0%B8%B2%E0%B8%93-usb-ttl-%E0%B8%AA%E0%B8%B3%E0%B8%AB%E0%B8%A3%E0%B8%B1%E0%B8%9A-arduino-%E0%B8%9E%E0%B8%A3%E0%B9%89%E0%B8%AD%E0%B8%A1%E0%B8%AA%E0%B8%B2%E0%B8%A2-usb-to-uart-cp2102-with-dtr-cts-pinout-ver3-0) | 1 |
| 33 | LED RGB 5mm (http://www.arduinoall.com/product/189/%E0%B9%84%E0%B8%9F-led-3-%E0%B8%AA%E0%B8%B5-5mm-rgb-led-%E0%B8%88%E0%B8%B3%E0%B8%99%E0%B8%A7%E0%B8%99-3-%E0%B8%94%E0%B8%A7%E0%B8%87) | 1 |
